03 is300 electircal problem
Hey guys im new to the site just bought a 03 is300 120k beautiful car runs great!!! BUT this thing started last week car runs and drives no problem but have no power to the dash. Cluster,radio,a/c control,power,windows, headlights, taillights dont work seats go back and forth no problems. I have checked fuses, fuseable links even changed tail relay along with new battery. Sometimes it works other times it dont does anybody know where all the grounds are maybe check them?
You may want to check my.is site. Go to the mobiletronics section, useful posts. You'll find what you need to identify grounding points and power sources.
It sounds like there's oxidation on either a fuse or a relay. Did you check under the hood as well as the driver's side cowl?
I have checked all fuses and relay i thought others would have had this problem. Its weird cuz i tried friday all day to get it to work and nothing but today i get ready to take to electrical shop and everything lit up perfect.
i suspect a grounding issue somewhere. i once had a similar problem and i ended up running a new ground to the back of the stereo which somehow fixed everything. I would take a multimeter to some of those grounds to see if there is a broken/loose connection somewhere.
So the electrical shop couldnt find anything wrong all grounds were fine butsays its all working properly
turbo_dreams
IS - 1st Gen (2001-2005)
02-07-11 09:58 PM
markA
06-11-07 04:08 PM
