R154 swap in is300 quick question
So i recently found a r154 trans pulled from a 1990 7mgte the guy was gonna put it in a 86-92 supra it includes the 5 speed transmission, clutch pedal, clutch master cylinder, slave cylinder, fluid lines, 2 point driveshaft, and flywheel just curious if anyone know what parts if any would would when swapping it in to the is300 thanks.
Are you manual or auto right now? Basic requirements will be the 1JZ/2JZ bellhousing, 1JZ/2JZ Flywheel, Clutch, driveshaft, Slave cylinder & shifter.
You will also need the manual pedal set from an IS300 and master cylinder including lines.
The MKIII driveshaft, lines, master cylinder, flywheel and bellhousing will not work.
bzebern
SC400 / 300 Classifieds
03-16-11 07:16 AM
sc1jzgte
Performance & Maintenance
06-01-08 09:27 AM
auto, brake, clutch, cylinder, driveshaft, interchangeable, is300, lexus, manual, master, masters, r154, set, swap, transmission
