is300 5MT
Hello y'all, i'm new in here! and i've been trying to get me an is300 for quite sometimes now! but i really like to get a manual if possible, so here's my question... if i do get a 5s MT is300 stock will i be able to put in a JDM 2jzgte with getrag r160 on it without any problem?
ECU:
MAF/MAP:
oil sump:
Mount:
any help or enlightenment would really be appreciated...
ECU:
MAF/MAP:
oil sump:
Mount:
ECU:
MAF/MAP:
oil sump:
Mount:
ECU:
MAF/MAP:
oil sump:
Mount:
you could also turbo and build the factory motor, then swap a V160 (V161 is a better choice due to rear gear ratio) in later...
webcosc4, my friend has a GTE 6speed swapped 03. Its is an originally auto. to keep all his gauges working he has the stock ecu piggy backed to the GTE ecu. The stock auto has codes for the auto tranny missing and that all. The engine it self runs off the GTE ecu and is tuned with a SAFC. He make 418whp with a BW 67 and 550cc inj at 16lbs. So it is doable the big cost after the purchase he said was a clutch $2300.
I have a Sport cross wagon with a W58 (not boosted yet) and all my gauges work.
hope this helps.
hope this helps.
hope this helps.
hope this helps.
There is a lot of info on the swap on the web to study but money would be the main thing with the swap a mkiv supra 6 speed motorset is around 8 grand! you could just about build your motor and turbo it for that.
