IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
who can tell me which is the fuel return pipe?
Old 09-13-13, 06:03 PM
slou
slou's Avatar
Default who can tell me which is the fuel return pipe?
Who can tell me which is the fuel return pipe from the fig? I need to drain the gas out of the tank.
Old 09-13-13, 09:54 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
modern cars don't have fuel return lines... sorry...
depending on which motor that is (sorry, not up on the newer IS's as much), it might not be a good idea to try what you are wanting to do anyways...
why do you need the fuel out of it?
Old 09-14-13, 01:24 AM
slou
slou's Avatar
I filled 3 gallon diesel into the gas tank, and drive 1 miles till is stopped. I need to drain the diesel out and filled the gas again!
Old 09-16-13, 06:46 AM
mitsuguy
mitsuguy's Avatar
Hopefully you have resolved this already, but if it was mine, I would pull the fuel pump out of the tank and pump out everything g in the tank manually with a hand pump or suction gun of some sorts...
JesLet
Performance & Maintenance
26
01-24-22 10:37 PM
ironcondor
11-14-15 03:44 PM
2012ISF
IS F (2008-2014)
11-13-13 07:33 AM
qewani1
04-14-09 03:09 PM
gsWarrior
Maintenance
06-01-05 03:10 AM
Quick Reply: who can tell me which is the fuel return pipe?
