IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Sportcross + VVTI 1JZ - Lessgo...
Old 10-19-13, 03:24 PM
DrGonzo
DrGonzo's Avatar
Default Sportcross + VVTI 1JZ - Lessgo...
So this is happening.
My Sportcross
+ JZX100 VVTI 1JZ with R154 (I think, someone help me ID this, block number 6140948 with ECU 89661 22790 and the pins match JZX100 plug diagrams). Remote shifter too so no shifter extension needed as far as I know.
To do/Shopping list for the next few weeks:
1. Driveshaftshop Driveshaft
2. Rad of some sort + EFans
3. 5 speed pedal assembly/slave cylinder + auto brake pedal replacement.
4. Timing belt/tensioner/seals replacement before going in
5. Intercooler/piping is gonna wait for the moment since Ill prob be fabbing up piping so I dont have to bother with ABS relocate and I dont wanna chop up a recently replaced sportcross bumper too much. WIll be done as the final step when everything else is done.
Few questions for the peanut gallery -
1. R154 will be able to be mounted to the OEM A/T trans mount for 02-05 IS? Pt2 - This is a remote shifter assembly correct and I wont have to make a shifter extension?
2. Ive found this pinout but a bit of better documentation would be amazing.
3. What is the general consensus on the DBW? Can I keep current DBW pedal or should I just go cable?
4. Will VVTI 2JZGE Starter work? Kinda ****ed the other one up compression testing.
Taking the dually to go pick up the motor middle of this week. Should be good times. Updates will follow.
Old 10-20-13, 07:13 AM
civicdrivr
civicdrivr's Avatar
You have my attention....
(Can't help with tranny identification unfortunately)
Sent from my Nexus 4 using IB AutoGroup
Old 10-20-13, 07:30 PM
handoverfi
handoverfi's Avatar
This should be good! I haven't seen many 1jz is300s but there's a 1st for everything. I'm actually doing a 2jzgte vvti is300 to daily. Good luck with your build!
Old 10-21-13, 05:55 AM
DrGonzo
DrGonzo's Avatar
Im paying for reduced headache in the trans department + Power FC. I called Apexi and they do not have a powerFC for the newer VVTI 2JZs. This they do. VVTI 2JZs go for about 2K up here with auto trans, but then after spending another 1300ish to get a R154 up to spec Im over what I spent. I like short stroke I6s so this is the way to go.
The trans is 100% what I need - no need to frankenstein a MK3 supra R154, find a 1J bellhousing, 1J flywheel, clutch, and shifter extension... Its all there. In addition, this is setting me up for a 1.5J down the road if needed so the displacement will be there in the future. Friend is making close to 400whp on stock clutch so Ill see how long that lasts for me after I do a quick resurface before sealing it up.
Old 10-30-13, 05:34 AM
is3wagon
is3wagon's Avatar
Its gonna be sweet when done! ! Good luck and cant wait to see the final product.
Old 11-09-13, 01:13 PM
DrGonzo
DrGonzo's Avatar
And the parts start coming in
Old 03-19-15, 07:17 PM
DrGonzo
DrGonzo's Avatar
So it runs. Turn the volume up.
Old 03-22-15, 05:26 PM
DrGonzo
DrGonzo's Avatar
Now need summer wheels. Because Im broke, it will probably be battles. CCWs long gone.
Old 03-23-15, 09:38 PM
RUCKER
RUCKER's Avatar
Clean ride bro.. The sport crosses have really grown on me. I don't know if there is a cleaner wagon out there right now.
mrlexus69
06-08-16 10:27 PM
MrFairlady
Performance & Maintenance
17
09-11-11 07:28 PM
tuninghaus
14
07-14-11 09:08 PM
craaaazzy
SC400 / 300 Classifieds
15
05-05-09 12:20 PM
dinhnerz
02-02-08 07:32 AM
Quick Reply: Sportcross + VVTI 1JZ - Lessgo...
