clear sidemarker prob
does anyone else have a problem with condensation getting in there clear sidemarkers? i just noticed one of mine has some in it. how can i fix it? or can i. thanks in advance.
What u need to do is take them off. Then either use a hair dryer or blow in them, to get out the water. You then, at the lining, would seal it up w/ some silicon tape. Its at any hardware store. Its white, and just put it around it; to seal up all of it, and make sure its tight. And you should be set.
-David
-David
