100,00 miles almost
The usual tune-up, plugs and wires, oil change, maybe check your cooling system. Timing belt, water pump and serpentine belt would be a good preventative maintenance package. If automatic, get a complete tranny fluid flush, not just draining the pan and replacing the filter, if manual, flushing the fluid by yourself isn't that hard. Check your tires and brakes, basically just replace everything that's somewhat easily replaceable and you should be good to go for another 100k.
