IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
2jz gte build
Old 12-13-14, 11:49 PM
Mikeohtran
Mikeohtran's Avatar
Default 2jz gte build
Hows it going people im getting ready to take on the challange of getting my car turbo I have a 03 is300 at. I bought the whole cx racing turbo kit 2.4mm head gasket from drift motion,fpr,wideband walbro 255 fuel pump and arp head stud .what I'm planning on getting next is the greedy emange ultimate and bigger injector can anyone tell me if I'm on the right path or if I'm missing anything else
Old 12-16-14, 11:52 AM
dsouthmia0
dsouthmia0's Avatar
I would go with stock gte head gasket. Are you running the GTE engine or are you using the GE?
Old 12-18-14, 08:52 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
This ^^^
2.4mm is way too thick for a head gasket
Emanage is barely acceptable, IMO, do a standalone.
Old 12-18-14, 06:31 PM
Mikeohtran
Mikeohtran's Avatar
i have the ge one I called driftmotion and that what he recommend me to go with to lower comp I was planning on going with the gte but he said it would have been almost no diff in compression
Old 12-18-14, 06:38 PM
mitsuguy
mitsuguy's Avatar
Gte gasket lowers compression to essentially 9.3 to 1. Which is perfect, imo.
I run 10:1 on e85 and wouldn't mind a little higher even. Spool is amazing, low end torque too.
Old 12-18-14, 08:49 PM
Mikeohtran
Mikeohtran's Avatar
Really yeah the guy from driftmotion said with the 2.4 I should be at 9.1 would did you do to your car.i live in Cali and the hugest is 91 I was thinking about going with meth injector
Old 12-18-14, 08:51 PM
mitsuguy
mitsuguy's Avatar
Mine is ge non vvti bottom end, ge gasket, stock vvti head, 67 mm turbo, 650 whp / 610 wtq
Old 12-18-14, 08:53 PM
Mikeohtran
Mikeohtran's Avatar
Oh dam that crazy did you get it tuned right away or did you drive it without and are you going full standalone and I live in Cali where 91 is the highest gas I was planning on using meth inj. To help keep it cool but where I love it doesn't get passed 70
TrueGS300
Performance
05-01-19 08:26 PM
grumpi300
Performance & Maintenance
23
12-06-15 02:27 AM
Deception
Performance
14
10-03-11 08:45 PM
durtysc300
02-08-09 05:25 PM
evileagle
18
09-05-07 05:01 PM
Quick Reply: 2jz gte build
