IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Resetting ECU-Which fuse exactly?
Old 04-01-15, 11:12 AM
HollyM
HollyM's Avatar
Default Resetting ECU-Which fuse exactly?
2002 IS300, which fuses do I pull?
Background: Check engine light has been on for over a year.
Got it scanned and replaced O2 bank 1 sensor. Light came back on the next day. I've already read plenty of posts of people who have replaced both only to have the light back on.
I need to pass emissions and I'm not about to start forking over tons of cash. Will resetting the ECU help me pass?
Just a girl.
THanks
Old 04-01-15, 01:56 PM
cp2
cp2's Avatar
have you tried disconnecting the pos on the battery? just remove the pos terminal for 30 sec and re-install. I've cleared a couple of cel's that way before.
Old 04-01-15, 02:02 PM
HollyM
HollyM's Avatar
It's intimidating to disconnect the battery. I'd rather pull a fuse but I' don't know which one..maybe the one that says ECU-B2 7.5A
I did at one time change my own battery on my CRX but for some reason pulling a fuse and putting it back in seems easier for me. I may do the battery thing. Thanks a lot for your response.
Old 04-01-15, 02:03 PM
HollyM
HollyM's Avatar
when you disconnected the pos on the battery and cleared your CEL, did it stay off for a good amount of time? or reappear...
Old 04-01-15, 02:15 PM
cp2
cp2's Avatar
well, it extinguished permanently for each respected issue. but in my case, it was usually the same issue, a dirty air temp sensor. but yes, it stayed off after each reset. good luck!
Old 04-05-15, 05:39 PM
buister
buister's Avatar
You will not pass smog by resetting the light then bring it right to the station. The smog station computer will see that it was reset recently and flag it as a fault. Typically to pass, the car has to be driven for so many miles and started so many times. I don't remember the exact numbers, but it takes roughly about 1 to 2 weeks of daily driving.
Ickey
32
09-08-20 09:18 AM
JKBHEAT
Performance & Maintenance
35
01-24-17 11:54 AM
Performance
29
09-10-16 01:18 PM
LexXxtacy
11-26-12 05:02 AM
Joeb427
02-24-08 03:16 PM
Quick Reply: Resetting ECU-Which fuse exactly?
