Can't disconnect door lock rods from clips
I am trying to remove the door lock actuator (driver's side, 2005 is300) to replace the locking motor. I can't get the rods out of the clips at the handle end. I can open the red and the white clip, but I can't get the rod end to snap out of the clip. Since I've got about 5 hours of work into this thing, I'm pretty worn out, and there must be something I'm missing.
For background, I have tools and I spend a lot of time rebuilding old motorcycles and scooters. I've rebuilt transmissions and engines, and I know my way around a shop.
I just can't seem to get these rods loose. So, if you can give me a clue what I'm doing wrong, I'd appreciate it.
Thanks
Thanks
Those clips are a pita to work with. It's best that you "feel" your way around the clips to determine which side has the opening. Unclip it from the rod and remove the rod from the actuator. I know this sounds easy, but it does take a bit of "finesse" to get it right.
I ended up breaking all of mine and had to order new clips. bought 10 of each from China on ebay for around $2 (each) so about $6 total.
It's a 5mm clip that connects to the door handle itself. fortunately mine was only on the drivers side so I only had to order for one side of the vehicle. I"m assuming the passenger side is different?
just confirmed the passenger side (right side are different). 69293-12060 are for the right side.
I got the rods separated, and nothing is broken. After 4 tries at the job, I finally took the door handle loose and moved it forward and away from the door. Then I could see the rod ends and I could get a better angle on separating them. It wasn't easy, but I did it. Putting the handle back in place was also a game, but it can be done.
Thanks for the help and the support. This is a complex job on the is300, maybe because the space is really tight.
jpw
Performance & Maintenance
05-01-15 12:11 AM
2002RX300
RX - 1st Gen (1999-2003)
01-03-11 04:30 PM
