Need break light help......
Ok. I got a little issue and its driving me nuts.
Recently my bulb light on cluster appeared. Had a friend push break while I found which one was bad. Its the circular break light on the trunk. I replaced the bulb with a dual filament as required. Issue did not go away. I even got a factory Lexus bulb and replaced. Still didn't work. The light is on when you turn on parking lights but when you hit the break it goes out. This is the only bulb that does this.
Has anyone else dealt with this?
I tried searching and could not find anything.
