IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Rewiring fog lights
Old 04-15-16, 11:41 AM
1997Soarer
1997Soarer's Avatar
Post Rewiring fog lights
Hello!
So I rewired the fog lights in my 2003 IS300 so that I can turn them on anytime the car is running.
And at the same time, they turn off when the car shuts off (exactly the same as the headlights do).
1. Modding the fog light switch so it works independently of the headlights
Remove the plastic cover underneath the steering column. This picture is taken from below the steering wheel looking up. You'll see wires in thin plastic wireloom that go from the big black connector on the left side and move down to the thicker wire loom on the right side.
Carefully cut this (and remove it completely if you like - it's what I did). See the WHITE with RED STRIPE wire that comes out of the far left side of the connector? Cut it at the plug. Then ground it. I extended it a bit so I could use the oem bolt on the left side as a ground.
2. Modding the fog light relay so it gets power any time the car is running
This is located just to the left of the passenger side fusebox in the passenger footwell. You're going to want to remove the whole lower right kickpanel to get at everything. Once you do that, find the RED with YELLOW STRIPE wire on the lower white plug just above the grey plug left of the fuses. Cut that wire pretty high up so you have some wire to work with. When I cut it, I didn't cut high enough so that's why there's that unnecessary connector on there. Splice the RED/YELLOW wire into the thicker BLACK with RED STRIPE wire on the grey plug. This wire is located on the far right top of the grey plug. Then secure the connection (remember, this is a live wire EVERYTIME the car is running).
All done
Old 04-17-16, 10:04 PM
stanghater
stanghater's Avatar
awesome! thanks. I used to cruise my car with the parking lights and fogs on after doing a rewire like this. This will be my next "mod" to my new IS
Old 04-20-16, 07:39 PM
1997Soarer
1997Soarer's Avatar
No problem! I noticed when I was looking for write ups, I found a lot on my.is but nothing on here. So I decided to post this here for future IS300 owners
Old 11-07-16, 01:41 PM
Ay-nako
Stop the Copy!
Ay-nako's Avatar
great information!
Old 11-07-16, 10:59 PM
Golden95SC
Golden95SC's Avatar
Very nice mod and great write up!
HarrierAWD
RX - 1st Gen (1999-2003)
01-06-20 02:50 AM
RamAirRckt
06-26-17 07:15 PM
GSLEX0586
01-17-12 12:17 PM
elsmooth
08-06-10 07:05 PM
jvsc300
SC- 1st Gen (1992-2000)
22
01-11-09 07:25 AM
Quick Reply: Rewiring fog lights
