IS Auto Geearbox question
Hi All,
Quick one.
Will an auto gearbox from a 2003 GS300 fit an 2003 IS300?
Alternatively is there anyone i can call to check this out?
Thanks
Chris
Quick one.
Thanks
Chris
Yes and no. Physically the transmission will fit. They're both a650e transmissions (as long as the trans is from a gs300 with vvti engine the older model used a 4 speed trans).
The difference is the tail shaft of the gs trans. It uses a 3 bolt flange with rubber flex plate. The is uses a slip yoke.
If you need an is trans look on craigs list they go for cheap.
