Serviced IS200, now have engine error codes
Hi Guys
i recently changed oil, filter and air filter. Car was running fine but now I have error codes P0300, P0301, 3 and 5. Misfire on cylinders.
So, I swapped coils and sparks and the same problem exists. BUT, I now have P0174 code that from what I've read is bank 2 running lean. I assume the two are related as the misfire presumably is because of the air / fuel mix.
Its late so cant go buy a stock filter to test but could the problem be because I've replaced the old stock filter with a KN filter? If so why are they sold if they don't work or is there a genuine issue with my motor if normally they do work.
Thoughts appreciated.
