installing fuel pressure regulator
how to install a fuel pressure regulator not firmiliar with lexus do you have a video on how to install it
you can email me back at derricke75@gmail.com thank you have a great day
The fuel pressure regulator sits in the tank on the IS300. https://www.discountpartsmonster.com...FY82gQodvCUJ3A
If you're wanting to install an aftermarket pressure regulator you'll need to either buy a new fuel rail with a return line fitting, or modify the factory rail to fit a return fitting. Then you'll have to run a return fuel line back to the tank.
