need help removing guage cluster to insyall trd one
ive got to be doing something wrong it seems as if im tearing the dash out instead of removing it please help waited over 6 weks to deliver and still cant install
brandon
brandon
CLUSTER INSTALL
HELLO,
WOW u got the TRD CLUSTER with theTACH in teh middle? IF U DID that is DOPE!... i wanted that one but what i found out is that the wiring on that cluster is not the same to our USDM connectors but it still is workable if u do some splicing and know which wire has the tach function...
AS for taking ur LEXUS cluster OUT.... there are TWO screws on top u need to unscrew... one screw on the bottom panel on ur right hand side. that takes the frame apart. once the frame is APART u need to disconnect ur light that lights up the cluster when ur headlamps are one.. the connector is directly behind the **** on ur left side. ONCE u take the frame off there are TWO more screws on the bottom which u will see holding the cluster and clips in place. also another screw on teh top which u will see... unscrew all three of those and then pull the cluster out .. once the cluster is OUT u need to disconnect the two connectors (BA-connectors) and then put in ur cluster.. but ur tach will nto work until u get that wiring figured out... OK so give me the update on ur cluster!....
PrOjeCt SeXy10
PrOjeCt SeXy10
spinedoc
10-18-01 08:08 AM
