IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Check engine light evap system
Old 05-05-18, 11:31 AM
Jsoto517
Jsoto517's Avatar
Default Check engine light evap system
hello guys,
my 01 Lexus IS 300 has recently giving the evap system code/check engine light. I replaced the fuel cap which seemed to be the easiest fix. I erased the code but the check engine light turned back on. Would anyone happen to know what could be causing this? Looked for cracked hoses near evap system but no luck. Would anyone recommend a good mechanic that could figure this out in souther California area near North San Diego?
Thanks for looking.
Only Mod is a K&N intake
Old 05-07-18, 09:35 AM
jadu
live.love.laugh.lexus
jadu's Avatar
I believe I replaced the fuel cap twice with this issue, because I cheaped out and bought an autozone cap. I ordered another cap through lexus and that seemed to do the trick.
Old 05-09-18, 01:41 PM
oriznal
oriznal's Avatar
i would try gas cap first, if check engine light pops back up again, recommend taking to local repair shop and get smoke test done. toyota evap systems usually is charcoal canister. if im not mistaken, everything pretty much is built-in inside of the canister.
Old 05-10-18, 08:04 AM
harlockssx
harlockssx's Avatar
Very common failure. Charcoal canister...which is very pricey! Can also be the VSV...
imakemap
Hybrid Technology
11-08-18 07:41 AM
Ariyanna
01-19-10 09:42 PM
northtide
SC- 1st Gen (1992-2000)
07-03-09 10:15 AM
02Ku
12-24-07 03:23 AM
wantalexus
Maintenance
08-28-03 11:06 AM
Quick Reply: Check engine light evap system
