2003 IS300 won't crank
After replacing the engine (still a 2jzge, just from a 2002 IS300), the car doesn't crank when I turn the key. I've already tested the battery and starter relay, both work fine. The starter works fine when I short the relay manually, but nothing happens when I turn the key. What could be the issue?
Have you checked the trigger lead going to the starter when you turn the key? If nothing is getting to it. I would say it is the ignition switch. Unless you have had a wreck or done some ind of swap.
YoshiMan
10-21-14 05:12 AM
