Is f wheels on is300?
Sorry to bring back an old thread but does anyone have anymore pictures. I'm thinking about putting my 2012 ISF wheels on my IS300 and was thinking of running 225/35/19 and 265/30/19. Also did any of you guys lower your IS300, I'm thinking about lowering it 1.5 to 2 inches all around on some HKS Hiperflex coilovers.
Thanks
Thanks
^^^^This is the ISF forum. Not sure if you have a Gen 1 or Gen 2 IS300. Assume it's a Gen 1. You would have better luck with your question here:
https://www.clublexus.com/forums/is-...2001-2005-166/
Lou
Lou
^^^^AFAIK the IS300 has 215/45/17 tires on it now. You would want to be close to the OD of 24.7". The closest to that in a 19" tire is 225/35/19 with an OD of 25.2". However the rear wheel of a 2012 ISF is 9.5" wide and that would be a stretch. A 235/35/19 would have an OD of 25.5" and would work on a 9.5" wheel.
Lou
Lou
I put my 2014 wheels on my ‘05. They have stock ISF tire sizes on them so they are a little taller than IS300 spec. It is also lowered so front tires rub the fender liners every once in a while. Rears, no issues. I’m only running these tires because they were new when I took them off of the F. They will be replaced with proper sizes when that time comes. This the only picture I have on my phone.
Beachtyme (04-11-21)
