Gio's Is300 Build
Gio's Is300 Build
This is my 2003 is300. So far I have put on BC Racing coil-overs, TRD shift ****, Nardi steering wheel with NRG quick release, and swapped all interior lights for white ones. I have also changed the headlight housings and put in new yellow LED fog lights. I painted the taillights, put in a k&n air filter, and did all the maintenance, timing, water pump, cam gear, cam seals, valve cover gasket, etc.
My goal with this car is to make around 350-400hp, 370z cd009 manual swap, Kaas 1.5 differential, full vertex kit, cx racing turbo kit piping. Good turbo and wastegate. Polyurethane bushings(upgrade overall suspension)
Any suggestions will help.
The following 2 users liked this post by Is3hunnah:
Modawgz (12-02-21),
TobiasSing (12-02-21)
Modawgz (12-02-21)
Modawgz (12-02-21)
Modawgz (12-02-21)
Modawgz (12-02-21)
Modawgz (12-02-21)
Is3hunnah (12-06-21)
I plan on restoring the dash and redying the interior black (door cards, headliner, etc) when I do the tranny swap and turbo setup. I should have time to do it while I wait for parts and machine work to be done.
Curated Content Editor
IS - 1st Gen (2001-2005)
05-19-21 09:33 AM
05-18-21 02:33 PM
