Dyno numbers on my IS..........
Final result 270.4 RWHP(corrected) and 298 RWTQ(corrected) Not bad for now.....got a few more things to do before supercharger goes in. I will install others "things" and do another dyno run next week. This is what it is for now. Not too bad at all!
I'm guessing you're on the bottle... Be carefull dude. those a/f ratios are wayyyyy lean. I actually don't think they are even acurate. Under full throttle even a stock IS is richer than that. Only closed loop cruising are they 14.7 and some partial throttle stuff. You need more fuel and in a bad way from the look of those a/f's.
Yes, lean is right. We even up'ed the fuel to a 36. I have to get a 38/40 and all will be good.I was running a 30! We ran out of time this evening for more dyno tuning, but I'll be back for more tuning next week. If you look at those a/f numbers, see the 268 hp run? See how he let off around 4000 rmp because it was lean. Then we put a 33 fuel jet in and wen't up a little, then we did a 36 jet for fuel and we got 270 hp. I am going to go to a 38 of 40 fuel. I'm hoping for 300 RWHP before supercharger goes in! Hats off and thanks to guys/gals at TPS!!!
is the person doing the dyno run going full throttle? 100% throttle? That's the only way to get it into open loop and start dumping some fuel. If you are juicing and your a/f ratios are higher than 13 you WILL blow your motor. not if, but when. If you boost w/out going full throttle it will go stupid lean.
I'm still not convinced those numbers are accurate and correct. I'd guess you would of blown your motor if they were that lean.
not bagging on you, i'm just looking out for you. Your a/f should be around 12:1. Anything over 13:1 is scarry unless you really know what's going on.
So you guys are saying the higher the number, the more chance of engine failure? I thought the lower the air/fiel mix...the worse off it was? Now I am confused
First, thanks for the help Wxman.
Second, UncleNick you should definately read up before something bad happens. If you don't understand what is good and what is bad then there will be expensive days in the not so distant future. I'm actually wondering what might of happened running the car that lean while spraying. At the minimum you were getting spark knock and the engine was retarding the hell out of the timing. I hope that was the only problem.
When spraying a IS you should only do this under full throttle and above 3000rpm's. Unless you know what you are doing and running a standalone management system, which you aren't, where you can control fuel at low rpms. The stock IS computer while in closed loop is going to stay at 14.7 and if you sprayed while it was like this it would go lean and potentially cause serious problems, which is what happened. Hopefully there was no damage.
You should lay off the juice until you're able to get to a tuner that is very knowlegable. I'm not sure where you're located, but if you post your location maybe I'll know of someone.
