TRD Suspension Kit - Facts
Registered User
For the past couple of days I've been researching the TRD Sportivo Kit for the IS300. As many of you know Carson Toyota sells those (there distributor being TRD USA). As a heads up, the part number indicated on the TRD USA website (00602-48000-018) is the Sportivo Kit for the GXE/SXE Chassis and not for the JCE10. I confirmed it with TRD when I called up and asked a series of questions, notably color of springs, sways, and spring rate. Color for the p/n mentioned above is:
springs = white
shocks = blue
sways = white
spring rate = 5.3kg/mm front, 5.7 kg/mm rear
What cdawg mentioned in his prior posts regarding the Sportivo kit is right. The GXE/SXE does not come in the blue springs and sways as previously mentioned. On other online stores that sell the Sportivo, you see the blue parts, have you noticed that the shocks themselves are for Mcpherson Struts and the springs are for the Mcphersons?
The kit that Technotezza purchased, the JCE10 model had a part number of (00602-48000-019). The only true way of knowing whether you got the right kit is if on the box you see the following numbers:
48030-JE100
48130-JE100
48800-JE100
Technotezza confirmed this as well.
After everything gotten straightened out with Carson Toyota and TRD USA, I ended up ordering (from Japan) the JCE10 kit (minus the sway bars) as I already have the L-Tuned sways. The JCE10 kit can be purchased in piecemeal fashion, not the SXE/GXE kit that TRD USA sells. Cost for shocks are $435 and springs (8.8 kg/mm front, 7.9 kg/mm rear) $285 with a 6-8 week delivery time.
springs = white
shocks = blue
sways = white
48030-JE100
48130-JE100
48800-JE100
0060248000018, 0060248000019, 48030je100, 48130je100, forum, gs, is300, jce10, kit, lexus, ltuned, sportivo, springs, suspension, trd, trdusa
