Teyes CC3 Android Head Unit
#62
I don't have a pic of my connections, but my stereo had one wire harness with 3 diff plugs (HI version, LO version, and if I remember correctly Optical). If yours is the same, you should find out which connector you should use and leave the others unconnected. I recommend that you use Google camera on your phone to translate the labels on the connectors.
Also, ensure you plug in as many connectors from the car harness into the original DVD portion as you can rather than plugging them into the wire harness from the android stereo.
#63
I have an older after market unit that works pretty well, but I want to get this for CarPlay and digital radio ... there are similar unbranded units on Aliexpress.
That's pretty annoying. Does the AC still do the auto fresh/recirculate air mode with this unit installed? I don't see the AUTO indicator next to the fresh/recirculate air buttons.
It’s normal. You probably just didn’t notice it before. This is the reason I am making my own climate control app for the Teyes. The reason the popup appears is because you have the climate control set to AUTO and in this mode the car is making small adjustments like fan speed and flow direction. These adjustments that the car is making automatically isn’t being done by you but essentially the app is listening for these changes as it cannot determine difference between the car making the change or you making it. So it thinks you changed a setting and hence shows the popup
verly6565
06-14-23 11:31 PM
