Best Aftermarket Battery for 2IS 250
Old 03-24-23 | 02:48 PM
ander2at's Avatar
ander2at
Question Best Aftermarket Battery for 2IS 250
Battery is starting to go, gonna replace it soon. Anyone have advice on the best aftermarket battery to use with this? I have a 2006 Lexus IS250.
Thanks in advance!
Old 03-24-23 | 03:09 PM
Protholl's Avatar
Protholl
Best would be a lithium or AGM battery. For my IS I went with a Duracell from Batteries+ with a coupon. No problems so far.
Old 03-24-23 | 04:05 PM
IntrinoX's Avatar
IntrinoX
Our cars are better off with flooded batteries, and Interstate’s Megatron Plus is the best!
Old 03-24-23 | 04:51 PM
MikeFig82's Avatar
MikeFig82
My battery perished a few months back. I went with a DieHard Gold this time. Seems to be the best around in specs on par with the Duracell in my area.
Old 03-24-23 | 06:20 PM
mandyfig's Avatar
mandyfig
My go to place is Costco.
Old 03-27-23 | 11:37 AM
Gville350's Avatar
Gville350
This! The OEM battery was Interstate; why not replace with the same AND save some money by purchasing at Costco.
Old 03-27-23 | 04:41 PM
Zmon's Avatar
Zmon
Adding onto this for another Costco suggestion. 109.99 for an Interstate branded battery with 700 CCAs, vs buying from Interstate directly ($160+ for 750 CCAs, shorter warranty at 30 months vs 36 at Costco).
Old 03-27-23 | 08:36 PM
ronkelley's Avatar
ronkelley
Why do you say that? Most people prefer the lower maintenance of the AGM.
https://www.crownbattery.com/news/ag...u-need-to-know
LexFinally (07-27-23)
Old 03-27-23 | 09:49 PM
Bichon's Avatar
Bichon
Super Moderator
The replacement batteries sold at Lexus dealers are made by Interstate, but the original battery in our (manufactured in Japan) vehicles was made by Panasonic.
No argument that the Costco battery is fine replacement, though.
Old 04-19-23 | 05:24 AM
Tussy's Avatar
Tussy
5th Gear
My agm battery died on me pretty new. While researching after the alternator failed I discovered Lexus/ Toyota charge with a fairly low voltage than AGM batteries like. Solution since I cant stand normal batteries after discovering AGM's was to order a voltage booster that helps maintains AGM's. If you still install AGM's I would advice using an outlet charger every now and then to avoid surprises.
video with ISF search for "Voltage Boost Mod - Lexus IS-F PCM Alternator Sensor Bypass"
Marylander
Hybrid Technology
07-21-23 10:58 PM
A320Captai
02-15-21 11:18 PM
metaleckz
06-20-19 09:31 PM
relax221
RX - 3rd Gen (2010-2015)
09-04-15 02:40 PM
19ES250
Maintenance
11-10-06 07:31 PM
