2012 IS250 AWD transmission question?
Hello all, I just picked up a 2012 IS250 AWD for my daughter. I want to do some maintenance before hand it it over to her. I did some research but one online site says AWD uses different gasket/filter vs RWD. So I'm confused and would like ask the community. Here are my questions. Thanks, Glen
1) Which transmission in 2012 IS250 AWD? A960E or A760H or A760E?
2) What fluid type does the transfer case take and capacity?
3) RWD and AWD both used the same transmission pan gasket and filter?
4) How much fluid do I need if I remove the pan? I used Valvoline MaxLife ATF, does not work for this car?
A760H
Filter p#
![](https://cimg5.ibsrv.net/gimg/www.clublexus.com-vbulletin/940x2000/screenshot_20230424_121645_ebay_ddafca1b637899f35f52486ec17018f2ee03249a.jpg)
![](https://cimg8.ibsrv.net/gimg/www.clublexus.com-vbulletin/940x2000/screenshot_20230424_121732_ebay_43fb1837c7d6764876c5efe916a7fad80b221c90.jpg)
A760H is a sealed transmission. It's a one piece transmission with the transfer case. You'd have to take it to the dealership for service. Unless you want to gamble with rendering your transmission useless.
There are a few methods as follows:
https://www.clublexus.com/forums/is-...a760e-rwd.html
Read last pages of my thread here. By all means this is not the correct way of doing it for AWD. You assume all the risks in doing it as my method shows. DO IT AT YOUR OWN RISK.
https://www.clublexus.com/forums/is-...l-removal.html
TomatoTheToolMan (12-07-23)
Look at door sticker on your vehicle. It has the transmission code. Lower left A/T code. The pan gaskets are not the same.
https://www.youtube.com/watch?v=i8EnjtKwIJU
Do you know the difference between A760H or A760E? One website says same gasket fits all three transmission. See below.
A760E A760H A960E TRANSMISSION PAN GASKET FITS '06-'15 LEXUS GS300 GS350 IS250
TRANSTEC / CORTEC 147300DF
Condition: NewLast edited by glenpointe; 04-24-23 at 02:23 PM.
Came across the following information for the A760E & A760H transmissions;
A760E 6 Speed Automatic Transmission RWD (Part 3516822020 2006 - 2015 IS250Transmission Oil Pan Gasket)
A760H 6 Speed Automatic Transmission AWD (Part 3516860010 2006 - 2015 IS250 & 2006 - 2022 IS350Transmission Oil Pan Gasket)
Mrdundo
07-12-19 06:00 PM
