Trunk support mount bracket defective?
I noticed for a while that that the trunk felt significantly heavier than usual so as as a precaution I ordered two new trunk struts.
Upon removing the liner, I noticed right away, the left strut just free falling off from the in the trunk wall itself to realize that it appears to be the mount/bracket itself has come off therefore it is not supporting the trunk at all. I am not sure if this is suppose to be welded or adhesive of some sort but it should not come off like that as I suspect this is some kind of defect. Anyone know anything about this?
I did replace the right strut as that was worn so at least the trunk feel to lift despite having one strut working now; will need Lexus to step in to see what they can do about that left side.
Added @Jeff Lange for visibility. Included pictures including the good right side.
primavera (05-24-23)
