Codes P0761 and P2714
1st Gear
I’m buying a 2008 is350 with 170k miles as a daily from the auction at my job. Everything feels fine it starts right up and appears to shift perfectly fine. I scanned it with a scanner from work and both the P0761 and P2714 codes popped up. Any idea as to why and what could possibly fix it?
I actually had this issue with my previous 2is, you need to replace your transmission solenoids. I went ahead and replaced all of them, but if you're up for it you can try and figure out which one is causing your issue. Pretty straightforward maintenance.
Find my previous comments on these codes. I had the repair done by dealer. Picture of cost on previous post. The repair can be DIY if your up for it. Will need to get under car with enough room to move around. I said screw it and bit the cost.
edgar23cb
02-15-22 06:24 PM
