Engine oil additives
Are these generally regarded as safe in a 2008? I wanted to check with the experts before I added anything. I seem to have a small leak when parked on an incline. Thank you!
IMHO: If you are thinking of adding something to the oil to stop the leak... don't.
The following 2 users liked this post by Protholl:
2013FSport (07-09-23),
JunoBR (07-09-23)
Try a high mileage full synthetic first. Worked for my Celica.
JunoBR (07-09-23)
Also only reason I see the leak on an incline is because the body panels under the car normally hold the leaked oil and now you're at the tipping point.
High mileage might take 1-2 full oil cycles to work, too. So be patient.
Stop leak can gum up the timing on the engine and other areas.
JunoBR (07-09-23)
