5th and 6th gear transmission shake?
Hello i have an automatic 2008 Lexus IS250 RWD purchased certified used in 2013 with 55k miles. It now has 167k miles. This happens Randomly but when it does when shifting into 5th and 6th gear only the car does a vibration for a few seconds and then goes away. You can give it gas and get thru it and eventually stops or you can let off the gas and it stops and then you give gas again and you can drive normally. Happens in hot or normal weather. I’m located in south FL. Any suggestions? I’m thinking maybe a transmission fluid drain and fill, or would a flush be better? I do most the common maintenance myself but I have not changed the transmission fluid for sure.
You should consider replacing the transmission strainer and fresh oil
Mitho1991 (04-27-24)
Please stop in at local parts store and have them scan it for pending codes. I bet you have misfire codes.
250's are known to carbon carbon up the intake and this is one of those signs. What is the service history, plugs, MAF, air filter, OCI?
my old scanner doesn't show any misfire codes and im planning on buying a better one (autel maxicom mk808). the car when it was under warranty at 58,580 miles Nov. 2013 dealer replaced the pistons and plugs due to the carbon build up. and at that time the symptom was when coming to a stop it would shake and misfire if i recall. air filter is k&n i clean every year. MAF is original and i clean also often. not sure what is OCI? thats all i have not done any thing else. only things that have gone is the fuel pump and the alternator its been a great reliable car. i do have it in mind to do new plugs my self and take a look at the intake and see if it has alot of build up but i didnt think about if this issue was carbon build up related but thanks i will try to put this on my list to verify. i got the trans fluid and rear diff. fluids im going to get on that asap. then ill check the plugs and intake and valves etc.
You can use a VCi cable for diagnosis
Para Toyota mini vci TIS Techstream V15.00.028 minivci FTDI para J2534 OBD OBD2 de diagnóstico del coche Auto escáner herramienta MINI-VCI Cable
https://a.aliexpress.com/_EzYaDVv
so after all these months of the shaking the ECU finally thru a code P2757 "Torque Converter clutch pressure control solenoid circuit performance or stuck in off position." the shaking had gotten a lot worst in the last few months. also when the code came up, pass 50mph the car would shake and not stop unlike before where it would shaking going into 5th gear and 6th but then it would settle.
Funny, even the pros didn't comment about the possibility that the issue might not be trans-related, that it could be a bent wheel causing feedback at certain MPHs. The trans codes COULD be unrelated. If the feedback you receive stays you at a certain MPH range no matter the gear you're in (test this by forcing the trans to stay in a specific gear via "manual mode"), then it's more likely to be a best wheel.
Good luck!
Good luck!
Well, sh/t, I didn't see that coming. In fact I worked at a transmission shop rebuilding them and can say I've never seen a converter cause a shake. My best guess is the failure mode has it going in and out of lockup repeatedly unless it shed clutch material and is actually out of balance which should make it shake always.
I'd pull the pan and open the filter looking for material that doesn't belong. Also, many make the assumption that codes pointing at shift, lockup, and pressure control solenoids mean those solenoids are bad. That may or may not be true. What is does mean is they need tested to verify function. If they are good, that means the fault lies elsewhere.
Has this ever had the fluid changed?
