MAF Plug - 2008 IS350
Other than cutting an existing engine harness, is there a way to get a OEM MAF plug for my 2008 IS350? I can repin the plug onto my engine wiring harness.
I cracked the piece that allows it to clip in and lock to the MAF and it comes loose on occasion causing a CEL.
Per your PM. Just cross-reference the part to the ISX50. Maybe call a dealer. Links are for reference.
Look here:
https://www.clublexus.com/forums/is-...l#post10848830
https://www.lexuspartsnow.com/parts/...ra2=&filter=()
kenji211 (10-12-23)
Happende to me, I used a twist tie to keep it place, it has held up, knock on wood. I periodically check tightness to make sure it is engaged.
