Test fitting 4is Is350 F sport wheels on 2is is350
Old 01-05-24, 01:16 PM
mattevo
mattevo's Avatar
Default Test fitting 4is Is350 F sport wheels on 2is is350
Wanted to share! New tires came in will install soon! Wheels fit and you can run 285/35/19 in the rear, for the front getting 235/40/19 oem 4is spec. And new lug nuts!
Old 01-05-24, 04:18 PM
primavera
primavera's Avatar
No rubbing in the front with 235 40? What are the wheels specs, offset?
Hopefully yours is RWD or taller tires in the back could potentially mess up the tranny on AWD
They look good
Old 01-06-24, 08:40 AM
mattevo
mattevo's Avatar
They look good
yeah rears are 19x9.5 +60 and front 19x8.5 +45
the tires on picture are 255, too big new tires came in today. And rwd
Old 01-06-24, 01:07 PM
primavera
primavera's Avatar
Is that 255/40 on the front axle? A 10mm spacer would push the wheel away from the control arm, making it 19x8.5 +35. Then again it could rub against fender tabs or something else. Try 235/40 instead?
The following 2 users liked this post by primavera:
ChiefP (01-08-24), mattevo (01-07-24)
Old 01-06-24, 01:39 PM
2013FSport
2013FSport's Avatar
Received 1,530 Likes on 1,273 Posts
Bummer! FWIW as you push it in the corners, anticipate that tire to shift 20 to 30mm up by the ball joint.
A previous car I had, had a solid 26mm between it 235/40R18 and it would whisper rub the steering knuckle leaving a clean spot on both sides.
That castle nut and pin would raise hell on a tire.
The following 2 users liked this post by 2013FSport:
mattevo (01-07-24), primavera (01-06-24)
Old 01-06-24, 02:05 PM
primavera
primavera's Avatar
Solid points. Too close for comfort if you ask me.
mattevo (01-07-24)
Old 01-07-24, 07:01 PM
mattevo
mattevo's Avatar
no spacers yet, will look into 15mm adapters or extend studs and do 10mm. Got new tires I have 235/40 will install soon
ChiefP (01-08-24)
Old 01-07-24, 07:02 PM
mattevo
mattevo's Avatar
i ordered oem is350 f sport 2021 tires, will have slight stretch, should be good, will post results soon
Old 01-07-24, 07:05 PM
mattevo
mattevo's Avatar
Rear spacing for educational purposes 285s
The following 2 users liked this post by mattevo:
2013FSport (01-08-24), primavera (01-07-24)
Old 01-08-24, 05:34 PM
2013FSport
2013FSport's Avatar
The rear can take it like a champ! It will also shift under side loading, make sure there is nothing sharp there.
I hope you get the fronts to fit without rubbing in the size you want.
Old 01-09-24, 05:21 PM
mattevo
mattevo's Avatar
Installed! Close fit! But fits only rubs on front fender liners while turning and bumps, will make some adjustments.
2013FSport (01-11-24), ChiefP (01-11-24)
Old 01-10-24, 05:30 AM
mandyfig
mandyfig's Avatar
Looks good!
mattevo (01-10-24)
Old 01-10-24, 08:47 AM
mattevo
mattevo's Avatar
Originally Posted by mandyfig
Looks good!
Thank you! makes it more modern, could use a 2is to 4is front bumper!
Old 01-10-24, 02:28 PM
primavera
primavera's Avatar
Little bit extra sidewall always looks great on these cars. So what tire sizes did you end up with?
Are you sure these are not 20s"? lol
ChiefP (01-11-24), mattevo (01-15-24)
Old 01-11-24, 04:47 PM
ChiefP
ChiefP's Avatar
Default Lowered? Cost of the wheels?
I like the look! I will be copying that 😆😂
is you car on stock suspension?
if you don’t mind sharing how much you got those rims? They sell around $1600 here in Los Angeles area on offer up.
mattevo (01-15-24)
Quick Reply: Test fitting 4is Is350 F sport wheels on 2is is350
