engine replacement
5th Gear
engine replacement
What is the average cost of an engine replacement on a 2012 IS 250?
1. it started with no heat and coolant low
2. replace the coolant hose, worked but then it didn't - kept an eye on coolant level... coolant will disappear, and the cool/hot level started to misread
3. took it back the mechanic, replace the thermostat - issue continue after I picked up the car.
4. took it back and the mechanic says - a new engine. My car had 160,000 miles.... I got a 2nd opinion.
2nd opinion - I need to replace the engine.
I love my car and I rather replace my engine vs. getting a car payment.
mslroman1 (02-20-24)
OP I can't answer your question as it varies by region. I'm only going to state that as you do your research, 06 to 2015 4GR-FSE and trans is a bolt it. As is 3GR-FSE 3liter. So if you find a 3GR-FSE w less miles or cheaper shipping, its an option. I suspect if RWD and comes with A960E, it is also a bolt in to 2015 but no proof. Just don't buy an FKS, only FSE.
firestart9 (02-20-24)
What happened before the engine blew?
Yodog (02-20-24)
etivane
11-02-17 05:04 AM
