Hi,
I am trying to fit SCION FRS/GT86/BRZ diff into IS 250 and I am wondering I want to put new
su00301008
su00301009
subframe bushings does IS250 has also two holes in that one bushing?
see 41651
Are these parts actually same on IS250 including
for anybody searching for this two holes are in all differentials on one side and on hole on another.
Therefore you have two different bushings as per picture.41651A and two hole 41651
I still cant comment about interchangibility/compatibility between FRS/GT86/BRZ and GS450H 3th 4th GEN GS300 3rd GEN IS250 XE20/30
What exact information are you looking for. Is it for the 2nd Gen IS platform or GS?
The Differential Insulators are listed below. See part numbers for each on the right. From there you can cross reference to which vehicles they fit.
OP - if you are seeking performance from say a BRZ LSD swap with Torsen center section, I'd highly recommend installing poly mounts. Using polyurethane on the 350 LSD eliminated wheel hop. Definitely worth it.
I am using FRS diff with 4.6 ratio. Are power flex inserts enough?
