IS 350 2011 - Limp Mode?
I bought the car yesterday from an auction and when I turned it on it won't go past 3K RPM'S. The car was in storage since 2021 and battery and battery in FOB was dead. I replaced both. Still same problem? Check engine light is on. What can I do? Have the ECU reset or scan for codes? Thanks for all your help!
The fault is for how much effort the throttle body is exerting to move. I wouldn't waste money buying a new maf sensor (wouldn't hurt to clean the maf anyway as part of regular maintenance) or gas pedal sensor. I wouldn't immediately assume an electrical issue or problem with the ecu If it idles fine and you can drive around, but it is possible.
If this was my car, I would start by cleaning and inspecting the throttle body, plug and wiring. If I were to blindly spend money, I'd hop on ebay and buy the cleanest looking used throttle body.
Husky2024 (06-18-24)
Search the forums unfortunately this is a "thing" for the nav/radio in this model. Then again did you press the DISP button on the left side of the screen yet?
No I did not press the display button. Am I supposed to press that first? I watched some videos on YouTube and will check and replace all radio, navigation and display fuses. Which might help. I hope. Thanks for any more tips.
kmax1980
RX - 3rd Gen (2010-2015)
02-20-24 10:55 AM
mdavid13
01-05-18 10:29 AM
