IS250 VVTi Cam gear replacement cost
My wife's 08 IS250 AWD has the notorious cold start rattle caused by the intake VVTi cam gear issue.
Has anyone had this replaced and if so could you share some ballpark repair costs?
Thank you!
Thank you!
R&R:
* Engine
* Oil pan
* Valve covers
* Timing cover
* Timing chains
* VVTi gears
* reinstall everything.
Likely need upper end gaskets, new chains and guides. Water pump if due?
Something like that. Call around and get a couple quotes.
I can't give you number but can speak to the labor. My only question is if someone is capable of pulling VVTi components without pulling Timing cover? If yes, valve covers come off and VVTi replaced. If no, it's gets expensive to pull the timing cover as you have to pull the engine.
R&R:
* Engine
* Oil pan
* Valve covers
* Timing cover
* Timing chains
* VVTi gears
R&R:
* Engine
* Oil pan
* Valve covers
* Timing cover
* Timing chains
* VVTi gears
And water pump??? There is an interval they should be changed? At 187k mi I'm not sure it has ever been replaced...
The car may only be "worth" $5000...if I'm looking at a $2-3000 repair it may have just be "it is what it is" lol.
seanmwple
09-28-20 05:08 PM
nch2oracer
08-09-07 04:04 PM
