A/C Not cold enough. Blend Door?
Hi all,
I'm in texas so it's definitely hot here. I noticed that when at standstill the A/C did not work well, and in general could be a lot cooler. Also noticed right vent was warmer than left vent.
Got my freon topped up and it's a bit cooler and the problem of both vents being at different temps went away, but the air still isn't as cold as I'd like it to be.
Could this be a symptom of the blend door actuator being stuck in some position? Or perhaps I need a new condensor?
2008 ISF
2008 ISF
When was the last time you replaced the cabin filter? Are there any obstructions in the front of the condensor (i.e. dirty, leaves in front other)?
DanceEng
02-16-24 10:32 AM
Aagarrison
10-07-19 01:56 PM
