Lexus Is250 2006 Crank no start Problem
8th Gear
Having problems with my Lexus IS250 2006 after changing the valve cover gaskets and also spark plugs and ignition coils the car is not starting. I believe the battery is good as it's reading 12Volts and the starter too since it’s cranking. I need advice as I'm stuck on how to turn it on, I've checked each sensor and connection to make sure I'm not just forgetting something.
Plz and thank you!
Plz and thank you!
