Exhaust nut and bolt
I have a full catback exhaust system and the new system comes with 6 pairs of nuts and bolts. 4 for the front end where it connects to the cats (2 per bank) and the other two for the connection just before the axle back section. All 6 for f The nuts and bolts supplied are the same. But looking at the current original ones on the car, the back 2 are some sort of long bolts with a really stiff spring. Question is do I use the original ones with spring or use the ones supplied without spring? What’s the purpose of a bolt with a spring at the back compared to just a straight bolt and but?
lexus-is2 (07-29-24)
If you notice the OEM gasket to axleback is a cup and socket. The springs allow some motion without introducing a leak. The special bolts typcally are so large in diameter up the shank they only work with OEM hardware. I'd imagine you can't use them and will be using those supplied.
Or just stick to the standard nut and bolt supplied? Should I use thread locker on the bolts and which colour?
thanks
lexus-is2 (07-30-24)
One concern I have using the original bolt with the spring is that it appears that the original bolt with spring threads into the midsection joint which has a factory welded nut. Therefore having the spring on the bolt end makes sense as that’s the side that could work itself lose from vibrations whereas the other side the nut is welded. Whereas for this new exhaust there is no welded nut and therefore if I was to put the original bolt with spring from one side and the use a nut on the other side, doesn’t that mean the vibrations are only being absorbed on the bolt end and not on the nut end potentially meaning that the vibrations can cause the nut end to come lose ? I’ve seen some people put double nuts. Not sure if that helps?
The exhaust seller told me to re-use the doughnut gasket on the section of their exhaust but their exhaust flange looks completely different. It’s in the same location where the current spring loaded joint it. But the difference is that the new exhaust the mid section and back section seem to mate up with a flat flange so I find it difficult to understand how the doughnut gasket will work on this joint. I’ve attached a picture of the joint where seller is telling me to re-use gasket but I just can’t see how the doughnut one will work on this as one side will go into the recess maybe but the other side is the same but the doughnut is flat on the opposite side
is this right? Am I missing something?
Recape please.
Catless midpipe and axleback? And axleback was bolted to OEM midpipe? If yes, you have problems.
The picture above requires a flat gasket, correct. OEM donut is no good.
I have OEM midpipe and F-Sport axleback, it retained the donut. That said, the F-Sport axleback is three pieces, the Y pipe uses flat flanges with steel gaskets. Think in terms of o-ring like thickness but steel with compression rings like some drain bolts.
I can't find the part number but it doesn't help you anyway.
Recape please.
the thing is that it’s made in 3 sections probably for easy assembly and transportation too. The new mid pipe goes to the back approximately where the original one used to sit and then it connects using the picture flange above to the rear sections. That is the flange that I can’t figure out what sort of gasket I need for it because they have not supplied a gasket for that. And that’s the same flange joint I was asking if I need to put oem spring bolts instead of the nut and bolt with washers that they supplied.
