mpg for new IS250?
From what I heard, lexus developed the engine as a new family and not the same as the 3.5 in the avalon. It might be based on it somewhat, but they said it was redically different, which is why it needed to be in its own engine family.
Originally Posted by XeroK00L
Why would any V6 or smaller engines be limited for use in just FWD or just RWD? Toyota may not be known to often apply one engine in both FWD and RWD cars, but other automakers do. Nissan's VQ engine is one good example.
The engine in the new IS is indeed the same as the one in the Avalon except for the use of direct injection, which doesn't affect the engine size either, meaning the Avalon could've gotten it too if Toyota made it so.
If one look at the specs, the IS has more hp and tourqe then the avalon because it is tuned differently to have more output then the avalon engine and mpg will be below the avalon somewhat with the corralation of higher hp and tourqe for the IS.
what lead me to believe the avalon has direct injection is the compression ratio, if you look at both engine, they are both 2GR engine with 11.8 to 1 compression ratio.
I could be wrong that maybe there is someway to achieve such a high compression ratio without having direct injection technology.
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
Originally Posted by GS3-03
I believed the avalon engine has direct injection also, toyota don't and never advertised it, I recalled the mention of the avalon having direct injection with double vvti.
I could be wrong that maybe there is someway to achieve such a high compression ratio without having direct injection technology.![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
So IS250 will have similar engine to GS300. That means better consumption than class leading GS300 (weight, smaller displacement engine), it all gives impression that IS250 should be class leading in mpg as well.
Abogos
06-25-21 06:21 AM
P128sniper
12-20-13 07:17 PM
