Oct Car & Driver Comparison (0-60 in 5.1 seconds)#1 330, #2 IS 350// Scans pg 6
Old 08-31-05, 04:55 PM
  #151
spwolf
spwolf's Avatar
Originally Posted by Legends6spd
This seems like great news for Lexus fans if it is true - if the C&D model isn't a superfreak of some sort.
I hate to splash cold water on a hot fire but let's examine how feasible a 5.1 0-60 really is for a 300hp automatic.
if you look at HP vs Weight of the IS350, the Lexus 5.6 sounds much more likely. If the car can really do a 5.1 w/ an automatic, imagine would what happen with a 6spd? It would take off another 0.4-0.5 off which would put it in 4.6-4.7 range. That is FASTER than a 333hp E46 M3. And that not to bring up the fact BMW hp ratings are undervalued since they transmission and power to the wheels are much more efficient than japanese cars w/ the same HP rating at the crank.
In another words. 5.1 0-60 is not likely to hold up w/ consistent testing. Sorry for being a pessemist but it would almost seem as if Lexus would defy physics to get that kinda #.
huh? ratings are as consistant as with other cars driven there. They were all driven under same conditions. So if you are saying that IS wont be able to achieve 5.1 run again, then G35 wont do 5.9 again (was it that much?). At the same time, 13.7 was blazingly fast too.
We have facts and you are posting opinions.
I am glad BMW is so superior. I think all IS drivers should wave when they pass BMW drivers in their superior cars with super duper undervalued ratings.
Old 08-31-05, 05:01 PM
  #152
Badman Forever
Badman Forever's Avatar
either way.. the is350 beats the 330i in majority of the categories. unlike the incompetent editors/test drivers at c&d, i know how to comprehend and do math. i wasn't surprised that they rated bmw #1, cause that's how all their cars are rated.. even if they break down.
Old 08-31-05, 05:03 PM
  #153
GlobeCLK
GlobeCLK's Avatar
Originally Posted by chiawei
No.
BMW quality is the best among the german car maker. And has been steadily improving. Although not as good as toyota/lexus. It's latest quality ranking is just behind honda/acura.
Isn't that Porsche?
Plus, Hyundai has the best quality among Korean automakers. However that's not exactly a reason to throw celebration parties.
Old 08-31-05, 05:09 PM
  #154
LexFather
Guest
Posts: n/a
Originally Posted by GlobeCLK
Isn't that Porsche?
Good to see u Globe.
I just thought about it, this time SHOULD NOT be that hard to believe. They got a 6 seconds FLAT with this same engine with 26 less HP in the HEAVIER Avalon..
It makes sense now.
Old 08-31-05, 05:33 PM
  #155
Gojirra99
Super Moderator
Senior Moderator
Gojirra99's Avatar
It makes sense now.
38 hp less & 29 lb.ft. less torque under new SAE :
Avalon - 268 hp @ 6200 rpm, 248 lb.-ft. @ 4700 rpm, 5 speed auto, cd=0.291, curb wt.=3545 lb.(touring model)
IS350 - 306 hp@6400 rpm, 277 lb.ft. @4800 rpm, 6 speed auto w/paddle, cd=0.28, curb wt.=3527 lb.
Old 08-31-05, 06:49 PM
  #156
LexFather
Guest
Posts: n/a
Holy crap, they weigh almost the same! The GS platform has tons to do with that for the IS.
Old 08-31-05, 07:11 PM
  #157
TheRupp
TheRupp's Avatar
Whoa that's lot of weight for such a small car
Impressive power comparison though, that extra 38 makes a huge difference, not to mention the 6 speed tranny
Old 08-31-05, 08:36 PM
  #158
davezaristo
davezaristo's Avatar
so where's the article?
Old 08-31-05, 08:52 PM
  #159
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
My slightly modded GS with the LSD rear, TC and valve body mod, has run a 5.2, 0 - 60 and it dynoed at 250 rwhp. I'm an engineer and work hard to make sure any data I post is consistent and reliable data. No need to defy physics here. The numbers are plausible.
Old 08-31-05, 10:21 PM
  #160
TheRupp
TheRupp's Avatar
It was up, but apparently the links were taken down, probably because of excessive bandwith
Old 09-01-05, 12:37 AM
  #161
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
plus, stuff like tq converter and gear ratio, they don't really show on the dyno curve. so much stuff that will affect the speed....
the m3 ONLY has 333hp, but they do 4.6sec. tell me how
Old 09-01-05, 01:54 AM
  #162
maz
maz's Avatar
Yes, it is true that the M3 has 333hp, but isn't that with the old SAE ratings. If you adjust the M3 hp ratings to follow the new standard, then the hp gap between the IS350 and the M3 will be much smaller.
Old 09-01-05, 05:55 AM
  #163
spwolf
spwolf's Avatar
also, consider how IS350 is modern car, heavier and with more goodies. While everyone says how IS350 is heavy, it is only 75lbs heavier than 330i with slightly less equipment. Thats 2% heavier and 25% more power.
Not only that, BUT EVERYONE except US mags have bashed new 3.0i engine as slowest in the class. UK and German mags when doing comparos with C350 and even A4 3.2FSI called the engine dissapointing.
Old 09-01-05, 06:10 AM
  #164
Gojirra99
Super Moderator
Senior Moderator
Gojirra99's Avatar
Not sure M3 hp will necessarily be affected with the new SAE rating though
I do agree that the IS350 's performance does not defy physics.
Old 09-01-05, 06:16 AM
  #165
spwolf
spwolf's Avatar
well, to be fair, old gen M3 is an awesome car but it is... old. Performance that was once awesome is now almost matched with 10k cheaper car.
New M3 should be brutal and straight out kill everything else in the same class. But at the same time, it is one class higher than IS350 and should not be compared to it. Maybe next ISh will have something to match its power...
Quick Reply: Oct Car & Driver Comparison (0-60 in 5.1 seconds)#1 330, #2 IS 350// Scans pg 6
