Oct Car & Driver Comparison (0-60 in 5.1 seconds)#1 330, #2 IS 350// Scans pg 6
Old 09-01-05, 06:49 AM
  #166
LexFather
Guest
Posts: n/a
I love the new IS numbers but M3 is a M3.
IS 350 does have more torque though
Old 09-01-05, 09:14 AM
  #167
Kbueno
Kbueno's Avatar
Thumbs up
WOW! 5.1...that's quick! C&D do like to invoke a lot of punishment to the car on launches to get low numbers (but since this is an automatic, all you can do is brake torque). If the forthcoming 6-spd will break the 5-sec barrier, I'm in!
Old 09-01-05, 09:26 AM
  #168
Gojirra99
Super Moderator
Senior Moderator
Gojirra99's Avatar
Originally Posted by rominl
plus, stuff like tq converter and gear ratio, they don't really show on the dyno curve. so much stuff that will affect the speed....
the m3 ONLY has 333hp, but they do 4.6sec. tell me how
M3's 3.2-liter power ratings are 333 hp at 7,900 rpm and 262 lb-ft of torque at 4,900 rpm., that's lower torque than IS350's 277.
Edmunds inside line tested the M3 at only 5.5 sec. 0-60mph LINK HERE You don't know how "slow " the M3 can be huh ? There are a couple more >5 sec times for the M3 HERE and HERE , and I'm sure there are more if you really look.
We all know that M3 had been tested as low as 4.6 sec. 0-60 mph, but I don't think we can conclude all those sub-5 seconds times tested for the M3 are suspect, just as the fact that edmunds tested the IS350 at 6 sec. does not make the 5.1 sec.by C & D suspect.
There's nothing unusual about different sources getting a wide range of results tested under different conditions with different drivers, the faster times are neither more nor less REAL than the slower ones.
Old 09-01-05, 09:38 AM
  #169
spwolf
spwolf's Avatar
word bro....
Old 09-01-05, 10:39 AM
  #170
INHOCJP
INHOCJP's Avatar
I totally agree. But any way you put it, the IS 350 should be FAST
Hey Lexus, where is my GS 460???
Old 09-01-05, 11:04 AM
  #171
GFerg
Speaks French in Russian
Senior Moderator
GFerg's Avatar
yep, thats right. Couldnt have said it better myself.
Old 09-01-05, 11:14 AM
  #172
bluestar
bluestar's Avatar
Originally Posted by spwolf
well, to be fair, old gen M3 is an awesome car but it is... old. Performance that was once awesome is now almost matched with 10k cheaper car.
New M3 should be brutal and straight out kill everything else in the same class. But at the same time, it is one class higher than IS350 and should not be compared to it. Maybe next ISh will have something to match its power...
The Lexus response to the next M3 is the 400HP IS500. Due here by MY2007/08-ish...
Old 09-01-05, 11:41 AM
  #173
flipside909
Lexus Connoisseur
flipside909's Avatar
That's been in the rumor mill..not official.
Old 09-01-05, 01:05 PM
  #174
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
maybe the e36 m3 is old, but the e46 is still holding its ground very strong imho. especially on the handling
Old 09-01-05, 01:09 PM
  #175
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
well of course there are all the variance and variables out there, but by looking at the whole general picture out there you can clearly see how fast the m3 is compared to say the old gs, is, and the new gs. granted the new is350 numbers here we see is only from one source, we will see about other reviews coming up.
what i would challenge is though, will we see faster speed from the is350 later on than the 5.1 we see here? i can't say definitely, but i am guessing "no". maybe someone will be crazy enough to do test of the is350 against the m3 if they feel the is350 is that much over the 330i, and we will see how it goes.
but i think you are taking my post the wrong way though. the reason i posted about the m3 was to say that although the m3 ONLY has 333hp, it can do mid 4. that means the is350 with relatively close hp and more tq, i am NOT surprised that it's doing low 5!!!!
Old 09-01-05, 01:10 PM
  #176
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
Originally Posted by maz
Yes, it is true that the M3 has 333hp, but isn't that with the old SAE ratings. If you adjust the M3 hp ratings to follow the new standard, then the hp gap between the IS350 and the M3 will be much smaller.
so you are just proving my point here that the is350 doing low 5 is more than possible?
Old 09-01-05, 01:35 PM
  #177
Agni88
Agni88's Avatar
Yep and the upcomming e90 M3(next fall) w/ 400hp+ should be even better! And they are FINNALY releasing a M3 4 door again!
Old 09-01-05, 02:18 PM
  #178
Gojirra99
Super Moderator
Senior Moderator
Gojirra99's Avatar
. . . but i think you are taking my post the wrong way though. the reason i posted about the m3 was to say that although the m3 ONLY has 333hp, it can do mid 4. that means the is350 with relatively close hp and more tq, i am NOT surprised that it's doing low 5!!!!
No you are taking my post the wrong way My post simply illustrates that many tests cannot get 4.8 -4.6 second range that people often raved about the M3, but that does not invalidate the fact that the M3 is capable of being this fast when driven under the most ideal conditions by the right drivers. Similarly, the IS350 can also do low 5's under the best of circumstances, even though some other tests may not achieve the same fast times.
Old 09-01-05, 02:53 PM
  #179
encore888
encore888's Avatar
I wonder if it'll get a 'GT' or other special designation...
Old 09-01-05, 05:41 PM
  #180
spwolf
spwolf's Avatar
heh, you wont see me dissing M3... I was drooling over that baby since saw it in Irvine first time (it was actually m3 convertible with some gun metal silver color). When I said old, I meant rest of the car... My favorite BMW would be E36 which I drove for a short while...
as to the posts about crazy CD numbers for IS, thank god this was an comparo with other cars persent. G35 and TL times were quite comparable to normal results and show just how much faster IS350 is.
If this was single test of IS350, obviously it could have been very suspect... but it wasnt - there were other cars on the track, driven under same conditions and same drivers.
Quick Reply: Oct Car & Driver Comparison (0-60 in 5.1 seconds)#1 330, #2 IS 350// Scans pg 6
