Lexus Emblems
Lexus Emblems
Does anyone know if there are holes behind the emblems on rear (ie. Lexus, IS250, IS350)?
Is it possible to take them off and leave it clean?
Originally Posted by IS_250
yep, just use some dental floss to loosen the emblem from the car. maybe use a hair dryer or heat gun to warm up the adhesive. you'll need more double sided tape to put them back on.
exclusive matchup
Originally Posted by jp430
The Lexus Emblem On The Back Of My 2001 Gs 430 Does Not Have Holes.
if you want to put them back on, you need to use the 3m industrial adhesive double sided tape, not just normal double sided tape
and to take them off, dental floss is more than enough. with the holes, you will need to fill them and repaint the whole trunk lid if you want to do it right. aftwards if you want to put back the emblems, you will need to cut the nipples and just stick the thing on
exclusive matchup
yes you can take them off and put them back on no problem
but paint them black? not sure if that's a good idea. i think the paint might peel pretty easily even if you sand and prime them (and sanding them isn't easy). plus it won't be even close to what dark chrome looks like
yep, i tried to debadge my IS on the first day. for sure the IS 250/350 badge has holes. i didnt even bother with the Lexus emblem on the left side.
I don't understand why a regular car driver would debadge their new car unless they wanted to hide the fact that they purchased a lower trim model, like IS_250 did with his car.
exclusive matchup
