IS350 Fog light bulb
Bulbs
Just to clearify:
High Beams-9005
Fog Lights-9006
Turn Signals-5964(Same as 7440 but yellow)
Parking Lights-194
Access:You'll need to remove the plastic covers in the engine compartment. Push down on the center of the clips holding the covers in place, then pull it straight out.
High Beams-Remove square cover in back of headlight housing, accessed through the engine compartment.
Fog Lights-There is an access cover underneath on the drivers side. Remove two plastic clips by prying out center of clip with a small screw driver. There is also a round rubber cover in the same location for access to adjustment screw for fog light.(Adjustment screw is for aiming)
For the passenger side you'll need to pull back the black plastic cover under the fog light or wheel well to gain access.
Parking lights-Same as high beams above.
Turn signal-This is where it gets tricky. Bare with me guys and gals. Basically, the only way to get to these is under the headlight assembly. It is easier to get to the ones on the passenger side. There are 4 bulbs total. Two on each side. Start by removing the lower portion of the front bumper. Look underneath and you'll see cut outs on the lower bumper where the mounting screws are. Remove all of the screws. On both ends, under the bumper, in front of the front tires, by the last mounting screw you'll see a round clip. Pry out the middle and remove. Remove the lower portion of the front bumper by sitting in front of the car and grabbing under the lower portion of the front bumper and gently pull towards you. It will pull straight out. Next, look under the section of the bumper where the fog light is and you will see a black plastic cover. Remove the front portion of this cover. You will need to muscle it out from under the bumper to gain access to the bottom of the fog light. Look for a bolt that holds the fog light in place and remove it. There is only one of these bolts on each foglight. Pry out the fog light assembly from behind the bumper. You'll need to disconnect the connector for the fog light bulbs and on the drivers side there is an extra connector you'll have to remove from the back of the fog light. Just reach in with a needle nose plier and squeeze the plastic clip and pull the extra connector through the little hole in the fog light housing. At this point, look up at the bottom of the headlight assembly through the cut out in the bumper for the fog lights. You'll see a white object protruding from the bottom of the headlight housing. That is actually the bottom of the turn signal bulb socket. Reach up and grasp the flat end. If I remember right, you will need to turn it counter clockwise to get it out. There should be two of these. Locate each one to replace the bulbs.
Now the drivers side. The inner bulb, closest to the grill, won't have a white plastic extention/protrution. But you can see the wires leading to the socket for the bulb. Just take a flashlight and look through the side where the grill is. The A/C line is in the way but you should be able to see it. Its kinda tight, but I managed to get my left hand in there by removing three round clips from a black plastic cover mounted on the frame rail of the car, under the head light assembly. The other bulb is accessable through the fog light cut out on the bumper. Its tight in there also because of the windshield washer reservour. Reach in and grasp the flat end and turn counter clockwise. The bulb and socket should come out like the other side did.
Sorry I don't have any pics at this time. The wifie is at school and she has the car with her. Hope this helps.
Will
High Beams-9005
Fog Lights-9006
Parking Lights-194
Will
Fog light bulbs.
Originally Posted by yoshi13
Installed Lonza fog light and Bl Hybrid parking light bulbs today.
Glad to hear that fog bulbs are 9006.
why not use 9005 for fog??
i'm guessing 9006(55w) vs 9005(65w).
it requires easy mod to use 9005 on 9006.
I cant wait to try this. anybody has done this so far on fog bulbs?
post pictures!!!
post pictures!!!
exclusive matchup
post pictures!!!
post pictures!!!
Originally Posted by rominl
very possible. look at how small the fog housing is. heat could be a problem
it is 65W vs 51w-55w for stock.
I just got Sylvania Silverstar 9005 for my front fog. Do you think there would be any heat problem?
when you say your just changin out the fog light bulbs, do you expect the same type of yellow output as the output on the is300, or will it be weaker? also, if this isnt the way, how do you get the foglights to be as powerfully yellow as the is300?
