IS350 Fog light bulb
Old 04-06-06, 08:14 AM
  #31
Mrbig
Mrbig's Avatar
Default Yellow Bulbs ?
Where to buy them ? Thanks for the info ....
Old 04-06-06, 08:37 AM
  #32
Mrbig
Mrbig's Avatar
Default Bulbs ?
I was looking around for bulbs and i saw some 9006 but they also have 9006XS ?
Old 04-06-06, 10:21 AM
  #33
Taka
Taka's Avatar
never heard of 9006XS so I searched:
"9006XS (straight back) type headlight bulbs
9006 (90 degree elbow) type headlight bulbs
Just the type of connector. Factory bulbs are the straight type, but you can get either one to fit."
Google
Old 04-06-06, 10:58 AM
  #34
Mrbig
Mrbig's Avatar
Default Bulbs ?
So it doesn't matter which you get ? I think there the regular 9006 bulbs thou !
Old 04-16-06, 11:47 AM
  #35
tgara
tgara's Avatar
Question Bulb list for new IS250
I'm seeing a lot of different info in this thread on the types of bulbs used in the IS.
My manual says:
Foglights: 9004, 55 Watts. The chart also refers to Type F, which at the bottom of the chart means HB4. HB4 is another index code for 9004 I believe. Thus a 9004 bulb and an HB4 Bulb are the same fitment.
Parking lights: 168 Wedge bulbs, 5 watts. The equivalent size is 194 or W5W I believe.
Highbeams: 9005, 65 Watts. Equivalent size is HB3.
Lowbeams: H11, 55 Watts.
There is no reference to 2006 bulbs in my manual.
My IS250 AWD has the HID and AFS lights, but the system is only on the lowbeams and gives a nice bluish light. The highbeam bulb and foglight bulb are conventional halogen bulbs, which are yellowish, and look dorky with the blue HIDs. I plan on replacing he Highbeam, Foglight, and parking bulb with some bluish bulbs so they will all match!
Old 04-16-06, 02:15 PM
  #36
Payam
Payam's Avatar
My manual says:
As long as you get 9006 and NOT 9004 for your fog lights you will be ok. It is a typo in the manual.
Old 04-16-06, 05:41 PM
  #37
wolverine
wolverine's Avatar
I just changed out my fog light bulbs for nokya yellows and they were a ***** to do ill post up pics later
Old 04-16-06, 07:18 PM
  #38
tgara
tgara's Avatar
Well, that's important information! Thanks very much!
Old 04-16-06, 09:39 PM
  #39
wolverine
wolverine's Avatar
heres my yellow fogs
Old 04-30-06, 01:03 AM
  #40
EBMCS03
EBMCS03's Avatar
My manual says:
I have no idea what the IS bulbs are but HB4 is 9006 not 9004. I know cuz my BMW uses HB4 or 9006 bulbs for the fog light also.
Dang... so it sounds like it'll be hard to get to the low beams.. i want to change out both the low beam and fogs to Sylvania Silverstars...
Old 04-30-06, 06:50 AM
  #41
Taka
Taka's Avatar
Default Silverstar 9005
just uploaded pic with silverstar 9005. need to change the parking light. What would be the matching Parking light with Stock HID? or Silverstar 9005?
TAKA
Old 04-30-06, 11:58 AM
  #42
EBMCS03
EBMCS03's Avatar
TAKA
Oh I really like this pic. Car looks evil !!!
Old 05-17-06, 05:02 PM
  #43
EBMCS03
EBMCS03's Avatar
Originally Posted by TAMR_GUS98
Fog Lights-There is an access cover underneath on the drivers side. Remove two plastic clips by prying out center of clip with a small screw driver. There is also a round rubber cover in the same location for access to adjustment screw for fog light.(Adjustment screw is for aiming)
For the passenger side you'll need to pull back the black plastic cover under the fog light or wheel well to gain access.
Ok I am trying to get access to the fogs right now and its a pain in the butt! How do you get the plastic wheel well out? I've unscrewed everything and took out all the pegs that i can find but i cant seem to get the wheel well out to get to the fogs.
I know about the access cover but the pasenger side doesnt have it. Any other hints?
Old 05-23-06, 12:37 PM
  #44
Nicelex13
Nicelex13's Avatar
hey wolverine what type of fogs are those? they look good
Old 05-23-06, 01:13 PM
  #45
mr.BeboT
mr.BeboT's Avatar
TAKA
it's too bad we can't just turn our fogs on in the US
Quick Reply: IS350 Fog light bulb
