IS350 Fog light bulb
Old 05-23-06, 02:56 PM
  #46
EBMCS03
EBMCS03's Avatar
Isnt the proper way to drive in dense fog to use parking lamps and just the fog lights? I thought that was the rule / law in Europe... Doesnt make sense how Toyota disabled that on our IS...
Old 05-23-06, 03:04 PM
  #47
tragic22
tragic22's Avatar
Does anybody have HID's that are more than 6000k. I'm dying to see how some real blue lights look on the IS.
And also what is the correct configuration for the Daytime Running Lights???
Old 05-23-06, 05:06 PM
  #48
gshb
gshb's Avatar
Originally Posted by EBMCS03
Oh I really like this pic. Car looks evil !!!
hey how did you turn on the fog lights without turning on your headlights?
Old 05-23-06, 07:39 PM
  #49
S.F.IS350
S.F.IS350's Avatar
Lightbulb Fog Light Bulbs Torture
I Just Did My Fog Light Swap Today Changed Them To Sylvania Silverstar 9006's
They Look Asume
Have Refractor 5-led On The Way
No Im Really Going To Have To Get Some Kind Of Hid's
So Any How, Any One That Said They Could Replace There Fog Lamp Bulbs In
Five Minutes Must Have No Care For There Fender And Plastic Wheel Well Covers
I Myslef Being A Mercedes Tech Found It Pretty Nerve Recking Prying My Wheel Well Out Agianst The Fender
Took Me About On Hour Untill I Got Everything To Lie Back Flat And Look Like
Factory Again
During This I Had The Vechile On A Lift And Also Took The Lower Engine Panel Off Wow Thats Alot Of Screws
I Thought And Sl With About 8 Screws Was Alot To Do An Oil Change I Count About 16 Or So Scews Wow
Any One Who Does Replace There Fog Lamp Bubls Be Careful And Take Ur Time
It Will Be Worth It
Old 05-24-06, 08:35 AM
  #50
mr.BeboT
mr.BeboT's Avatar
When I took winter driving training in Wisconsin it was advised to just use fogs in dense fog (go figure.) It doesn't help that a lot of us have HiDs too, since the glare from not being able to turn those off pretty much reduces our fog lights to an aesthetic capacity.
Old 05-24-06, 12:30 PM
  #51
EBMCS03
EBMCS03's Avatar
Exactlly... thats what I thought... proper way to use Fogs is to JUST use fogs... but oh wells. I dont care. Not enough fog where I live...
Old 05-30-06, 05:14 PM
  #52
duey_17
duey_17's Avatar
Originally Posted by tgara
I'm seeing a lot of different info in this thread on the types of bulbs used in the IS.
My manual says:
Foglights: 9004, 55 Watts. The chart also refers to Type F, which at the bottom of the chart means HB4. HB4 is another index code for 9004 I believe. Thus a 9004 bulb and an HB4 Bulb are the same fitment.
Parking lights: 168 Wedge bulbs, 5 watts. The equivalent size is 194 or W5W I believe.
Highbeams: 9005, 65 Watts. Equivalent size is HB3.
Lowbeams: H11, 55 Watts.
There is no reference to 2006 bulbs in my manual.
My IS250 AWD has the HID and AFS lights, but the system is only on the lowbeams and gives a nice bluish light. The highbeam bulb and foglight bulb are conventional halogen bulbs, which are yellowish, and look dorky with the blue HIDs. I plan on replacing he Highbeam, Foglight, and parking bulb with some bluish bulbs so they will all match!
HB4 is NOT the same as 9004. HB4 = 9006, and 9004 = HB1. The bulb type (F, HB4) in the manual is correct, however the 9004 is a typo. The bulb is a 9006, aka HB4 bulb.
(I am referring to the IS 350 manual, pg. 388)
Old 06-09-06, 05:14 PM
  #53
Johnny Mo
GX and 2IS Moderator
Johnny Mo's Avatar
Default Changing fog light bulbs
Guys,
according to the dealer's service manual the entire front bumper needs to be removed in order to change the fog light bulbs. I suppose you can do it the way many have suggested, but that will explain the inner fender liner not flattening out for a while. Gonna try this myself this weekend. Will try to take pics and will try to scan and post the instructions.
Old 06-09-06, 05:36 PM
  #54
EBMCS03
EBMCS03's Avatar
Nope, I didnt have any problems with the wheel well not flattening out at all. it just went back into shape instantly... But what did happen is I left a crease... so just be careful if you see it folding up try pulling another way. It can be done.
Old 06-09-06, 07:18 PM
  #55
Johnny Mo
Johnny Mo's Avatar
Default I changed them (service manual way)
Originally posted here
Old 06-10-06, 02:57 PM
  #56
akkord
akkord's Avatar
Took me all about 10 min to change out my fog light bulbs...1 bolt, 2 plastic clip type screws...pull the lining out a couple inches...stick your hand in and get the bulb...turn the wheels for easier access...went back into place easily...no creases, bends, nothing...the plastic lining is only pulled out for 30sec to a min to change the bulb then you put it back in place...
looking at the turn signals though...that looks a little tougher and I haven't had time to do it yet...thinking you have to go from the bottom like posted on the other threads or take off the bumper...
ALEX250
07-27-18 03:18 PM
TheKirby
01-16-13 04:39 AM
mikes rx
10-01-07 12:11 AM
GS3-Kid858
09-28-01 12:12 AM
Quick Reply: IS350 Fog light bulb
