IS350 Fog light bulb
Old 11-08-05, 08:19 PM
ShowcarA4
ShowcarA4's Avatar
Default IS350 Fog light bulb
Whats up all
Just wanted to know if anyome what size the fog light bulb is in the IS250/350. I wanted to swap the whites out witth yellow bulbs.
Mike
Old 11-08-05, 08:36 PM
pinoychris
pinoychris's Avatar
Pg 383 of the owners manual
Front Fog Lights 9004
Old 11-09-05, 04:38 AM
ShowcarA4
ShowcarA4's Avatar
thanks for the info
Old 11-10-05, 11:02 AM
mofogasm
mofogasm's Avatar
H11 for low, 9005 for high, and 9004 for fogs.
Old 11-13-05, 06:39 PM
MLEE4984
MLEE4984's Avatar
So I am guessing the DRL bulbs are 9005 correct?
Old 11-15-05, 01:36 AM
yoshi13
yoshi13's Avatar
Did anyone notice in the manual that the fog lights = 9004 was "Type F", which is then listed as HB4 on the bottom?? Typo?
Old 11-15-05, 08:09 AM
IS350PSK
IS350PSK's Avatar
Default Jdm Yellow
The bulb is 9004 and I'm doing the same thing. I just ordered 9004 bulbs in JDM yellow from Luminicsbulbs.com. When you order the bulbs it comes with a free LED light keychain, a plus I guess.
Old 11-15-05, 08:29 AM
IS 250 FAN
IS 250 FAN's Avatar
why would you want to change out white for yellow?
Old 11-16-05, 01:03 AM
yoshi13
yoshi13's Avatar
Might want to return those 9004s... I was a bit skeptical so I took out the fog light bulb today. Sure enough, they were 9006 Sylvanias.
Old 11-16-05, 07:34 AM
jlin101
jlin101's Avatar
how hard is it to remove the fog light bulbs? Do you have to remove the fog light housing, or do you just unscrew the bulb from behind?
Old 11-16-05, 09:16 AM
brewkp4
brewkp4's Avatar
Generally how much do these bulbs cost?
Old 11-16-05, 02:50 PM
yoshi13
yoshi13's Avatar
The eaisest way is to access the fog light housing from behind the bumper. Just tilt your wheel in to get some room, fully remove 2 of the push in screws and unscrew the philips head one on the bottom of the bumper, pry out the plastic gurard (use a flat head screwdriver carefully) and you can get access to the back of the bulb. Rotate counterclockwise and you're in business.
As for the cost, some of these bulbs go for as cheap as $15 on ebay, but the higher quality ones from Piaa are upwards towards $80-100 a pair.
Old 11-16-05, 03:04 PM
jlin101
jlin101's Avatar
Just what I was afraid of--I had to do that to access Infiti G35's headlights and it was a major pain. Are IS 's headlights/turn signals also accessed this way?
Old 11-16-05, 03:15 PM
yoshi13
yoshi13's Avatar
The headlights and turn signals are accessed in the engine compartment. The high beam and parking light are easy to get to, but i couldn't see that much room to work with the low beams or the signal lights.
Old 11-16-05, 03:52 PM
RCFormante
Supercharged!
RCFormante's Avatar
For the turn signals, I think your gonna have either access under the bumper or remove the bumper to install the lights because it looks like there is no way to access it from the engine compartment.
Quick Reply: IS350 Fog light bulb
