Installing a sub in the IS 250
I had a few hours to kill and decided that id install a subwoofer and amp in my IS today. For those with weak mechanical ability or dont like tearing apart a brand new car you'll be better off paying a professional. If you have done this before its pretty straighforward. To install the power cable it is much easier to remove the battery. Trust me, remove the battery. I kept getting my fingers pinched in the hood support springs and it really pissed me off. There is a grommet on the firewall next to the battery. Using a flexible metal rod i snaked the cable into the the interior and ran it underneath the carpet. At this time i also ran a remote wire from the fuse box.
To send audio signal to the amp i decided to disconnect the stock sub and feed the output into my amp. Luckly for me the amp i used accepts a line level signal, basically i can use the signal from the stock radio without using RCA inputs. Sounds easy enough, but getting to the stock sub is a real PITA. the rear seats must be removed to access the sub. The bottom cushion is held on by clips, just pull up and slide it out. The seat backs has (8) 12mm bolts that need to be removed. Once the bolts are removed, its probably best to have another person help one on each side and slide the seat back up and out.
I decided not to remove the rear deck completely and just pop a few of the clips to disconnect the subwoofer harness. I slid the harness out one of the holes to tap the wires for the audio signal. I used the pink wire (+) and light blue wire (-).
Heres the finished product. Not exactly the best high end stuff, but something to add that extra bottom end that i thought was missing. Honestly I think 1 12" sub is too much, but I had this JL audio 12" and Alpine V12 amp laying around. I plan on using a smaller box with a 10" sub. If I ever find the time i plan on replacing all the speakers and using the JL Audio Cleansweep and a 5 channel amp, but this will do for now. Sorry about the long post. Hopefully this helps anyone thinking about installing a sub in their IS.
![](http://pics.montypics.com/stkd16z6/2005-11-12/1131848905_picture_001.jpg)
![](http://pics.montypics.com/stkd16z6/2005-11-12/1131849091_picture_002.jpg)
![](http://pics.montypics.com/stkd16z6/2005-11-12/1131849592_picture_003.jpg)
![](http://pics.montypics.com/stkd16z6/2005-11-12/1131849693_picture_004.jpg)
![](http://pics.montypics.com/stkd16z6/2005-11-12/1131849801_picture_006.jpg)
4FR1SCO5 (01-20-20)
Did you keep the factory head unit? Also, how is the sound? I have a JL Audio 300/4 and wanted to add a sub but did not wish to change out the HU. I was told that if I kept the stock system and add the sub, it would cancel out the rear speaker components.
Thanks....
Thanks....
wow props to you. I installed my own stereo on my Acura Integra a year ago. comps, rear, sub, 2 amps, etc. After everything was apart, front door panels, rear panel, etc My car looked like a disaster!!
I dont think I would be able to do this on a BRAND NEW car.
Thanks....![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
Thanks....
Awesome! Thanks a lot for posting this since I would be upgrading to an aftermarket sub after I get my IS 350 sport package in spring/early summer. Somebody had to do it first and I think you are the first one probably to buy him/herself a new IS and install a sub in it. Cool to know hey?
There is also a new website for IS owner/enthusiasts to check out: www.is350forums.com
I've been wanting to do that to my car since the day I bought it. I have an eight in JL sub and a JL amp left over from my old car. The only thing I don't like about the factory radio is the sub in the back, it sounds like crap.
Thanks for posint this. I've been trying to figure out how to get to that factory sub for 8 months now
Damn, thank you!! I have been wanting to do this as well (i have a 10" sub from my old car). And the cleansweep box sounds extremly interesting! Does it work as well as the site says? A little steep in price, but if it works well, then sign me up! I may just have to redo the entire car system
(something i wasn't going to do due to the non-standard deck)
JL Audio rocks!!!
On my auto show Corolla I installed everything from Marathon Bass woofers, to Kicker, to Bazooka, to MTX, etc, etc and the BEST by far is JL audio. Not only that, but if you buy one of their design enclosures, the bass sounds unbelievable.
A friend of mine bought one of JL'S enclosures with one 8" sub and I laughed in his face because I think he paid $220.00 for it and I didn't think it was going to be loud, but to my surprise that thing hit like he had two 15"s in the back. Nice setup!!!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Just out of curiosity, has any replaced the factory subwoofer with a mono amp that you can control the amount of bass you want in the factory for. I am looking into possibly hooking up a mono amp from the inputs for the factory subwoofer and putting a better subwoofer in the factory location but having more control on how much bass i want, the factory system sounds great just needs a little more bump , Any suggestions
perhaps not updated, but the 07 removal should be for the 2gen IS
https://www.clublexus.com/forums/is-...t-removal.html
I did this a year or two ago for a different reason but steps are the same.
