Speaker sizes for IS250 w/o ML
This has been frequently discussed here. . The stock audio system has the same set (or at least the same-sized set) of three speakers in each door, 6¼", 2½" & 1", plus an 8" woofer in the rear deck.
The Mark Levinson premium system changes this a bit -- it not only adds a 2½" speaker in the top of the dashboard, but also reduces the rear door mounted speakers to two, 1" & 4", and adds two 2½" speakers in the rear deck. . I'd guess the added front and rear deck speakers are for center (dialog) channel and rear (ambience) channel signals, which is consistent with the DVD and DVD-Audio capability in the ML system, at least if ML is part of the nav system.
Originally Posted by mofogasm
i have a stock 250 and it has a center speaker in the front dash? unless it's just the grill
I replaced all the door speakers with Infinity speakers. I put a set of 6 1/2 components in the front and rear doors, along with 3.5 2way in the doors. If you dont have ML there is nothing under the grill but there is a wire that could be used to power a speaker. i will try and add a speaker to the wire and see if it works in the next week. Im also so adding a Boston Acoustics G512-44 12" sub amped by a the kicker400.1 mono and im also going to have a infinity amp installed to push 111 watts to both of the 6.5 components.
If any one knows a speakers that i could place in the factory location on the rear deck let me know please.
Jahseriah (09-12-24)
Does anyone know the front speakers mounting depth?
I'm considering these for my front speakers
http://www.edesignaudio.com/edv2/pro...roducts_id=519
think these will fit?
