climate control display
Originally Posted by hashs99
I looked up 2 phone numbers last night, in a part of town I wasn't too familiar with. Ended up being really useful and it impressed the people I was with. Is it worth $2.5k???? Maybe to some, maybe not to others.
Can't wait to get a BT phone, damn Nextel.
Everytime I get into my IS350 the air circulation goes to outside air, regardless of what I had it on when I turned it off! The system always stays on "Auto" with A/C on.
Is there a way to make the IS350 always keep the air circulation mode on AUTO (the middle LED)?
Originally Posted by jlin101
same here; I believe the default position is already auto (between fresh and recirc, based on the temp and humidity) for Lexus; however, the middle auto (smog sensor) is not on unless you press it. Quite of a hassel.
OK so I just got back from Lexus Kearny Mesa (San Diego). They had one of their techs attempt to put the air circulation mode into AUTO when the car starts by using the Lexus Personalized Settings (LPS) and no matter which option he used (AUTO or MANUAL), the car refused to go into AUTO circulation mode on start-up! The tech got frustrated and called his Master Tech over to look into. They both agreed that something funny is going on with the LPS setting.
They are going to call their Lexus region rep and escalate the "problem" to see if it is a known issue. Anyone else have this problem?
I'm having the same problem and it's pretty annoying but I haven't brought it in to anybody. If they tell you how to fix it, please let us know. Much appreciated
Originally Posted by TimboIS
Auto Recirculation is NOT an LPS setting.
Originally Posted by Duke02
Any idea how to make Auto the default setting? It seems counterintuitive that you have to tell the system to use an Auto setting for recirc when the rest of the system is set to auto. May it was just an oversight
I don't think americans would tolerate having a metric mode As this has been discussed before, people have asked their service dept, there is no switch or LPS setting to change it (or on any Lexus vehicle).
