Brakes or paddle shifters to slow down?
Which is preferred? Also, if you are using the paddle shifters, what rpm should you downshift?
I prefer to use the brakes. I figure brakes are cheaper to replace than a transmission. Plus, what I've experienced is if you're going too fast, the paddle-down shift won't happen immediately. The computer will wait until the engine RPM is at a safe speed before the down shift is executed.
Yeah, I agree. Brakes are definitely cheaper to replace than transmission or clutch (if you're driving a manual). My understanding is that you brake to slow the car down and downshift is to put the car in the right gear to accelerate out of the corner. my reference is "Going Faster" by the Skip Barber Racing School...so i think they know what they're talking about although i only read a few chapters...
Originally Posted by mhiggi02
I traded in a 2003 325i on my IS 250. The BMW had a built-in safety feature where it would automatically up shift at red line if in manual mode. Does the IS do the same?
....Plus, what I've experienced is if you're going too fast, the paddle-down shift won't happen immediately. The computer will wait until the engine RPM is at a safe speed before the down shift is executed.
One thing that I noticed that's different from other cars while in "S" mode is that the IS250 doesn't downshift (automatically) to 1st gear once stopped if you were in a higher gear. On a lot of Acura cars, this is done automatically so that when you take off, you're in 1st gear again.
Lex
Lex
Lex
Lex
I'm interested because my parents are probably heading to the Lexus dealer this weekend to take a good look at an AWD IS250.
Guys, slightly OT and I'm not sure if this applies to the IS (hopefully none of you find out, or are in a safe place to test it) but when I used the e-shift in my GS in snow to slow down in snowy / icy conditions, the wheels would sometimes grab / lock up and slide a bit.
Kind of goes contrary to what you'd expect... in my old manual car, I'd use gearing instead of brakes to slow myself down in slick conditions, but the e-shift auto didn't work nearly as effectively.
Lex
Lex
Originally Posted by jlin101
it DOES automatically downshift to 1st when you stop--just change the LCD display to current gear and you'll see. The digital display next to "S" merely indicates the highest gear available at the time.
If you are in sport mode with the gear set at "3" and you come to a stop light, the car will go to first then shift to second but it will not pass third gear until you upshift again. Hope that helps.
